GetUCSMatrix method example
Sub GetUCSMatrix_Example()
    ' This example creates a new UCS and finds the UCS matrix for it.
    ' It then creates a circle using WCS coordinates and
    ' transforms the circle for the UCS.
    ' Define a new UCS and turn on the UCS icon at the origin.
    Dim ucsObj As AcadUCS
    Dim origin(0 To 2) As Double
    Dim xAxisPoint(0 To 2) As Double
    Dim yAxisPoint(0 To 2) As Double
    origin(0) = 2: origin(1) = 2: origin(2) = 0
    xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) = 0
    yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) = 0
    Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
    ThisDrawing.ActiveUCS = ucsObj
    ThisDrawing.ActiveViewport.UCSIconOn = True
    ThisDrawing.ActiveViewport.UCSIconAtOrigin = True
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ' Create a circle using WCS coordinates
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 1: center(1) = 1: center(2) = 0
    radius = 0.5
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
    ZoomAll
    ' Get the UCS transformation matrix
    Dim TransMatrix As Variant
    TransMatrix = ucsObj.GetUCSMatrix()
    ' Transform the circle to the UCS coordinates
    MsgBox "Transform the circle.", , "GetUCSMatrix Example"
    circleObj.TransformBy (TransMatrix)
    circleObj.Update
    MsgBox "The circle is transformed.", , "GetUCSMatrix Example"
End Sub
