IntersectWith method
Member of BricscadDb.AcadAttribute
     Returns the intersection points between given objects.
Syntax
objectVariable = theObject.IntersectWith(intersectingObject, AcExtendOption)
Where:
     theObject is the first BricsCAD entity to be intersected;
     intersectingObject is the second BricsCAD entity to be intersected;
     Option is one of the following constants (AcExtendOption) for intersections:
     acExtendBoth = 3 (extends both entities if necessary)
     acExtendNone = 0 (does not extend either entity)
     acExtendOtherEntity = 2 (extends the second entity)
     acExtendThisEntity = 1 (extends the first entity)
Examples...
IntersectWith method example
