Sub Open_Example() ' The following example opens "C:package.dwg" file. ' You may need to change the drawing path and name to reflect a valid ' BricsCAD drawing on your system. ThisDrawing.Application.Documents.Open ("D:/a/Blocks2D/Meubels/BEPL06_dubbel.dwg") End Sub
© Bricsys NV. All rights reserved. |
