Sub OwnerID_Example() ' This example adds a circle to the drawing and then finds the OwnerID for the object. Dim cenPt(0 To 2) As Double: cenPt(0) = 4: cenPt(1) = 2: cenPt(2) = 0 Dim dRadius As Double: dRadius = 2.5 'Add the arc to the .dwg Dim myCircle As AcadCircle Set myCircle = ThisDrawing.ModelSpace.AddCircle(cenPt, dRadius) ZoomAll MsgBox "The OwnerID for the Circle object is: " & myCircle.OwnerID End Sub
© Bricsys NV. All rights reserved. |
