Sets or returns whether the Attribute or AttributeDef is a preset attribute (True) or not (False). A preset attribute sets the attribute to its default, or preset, value when the user inserts the block. An attribute may exist as only one of four optional modes: constant, preset, invisible, or verify.
Syntax
Where:
BooleanVariable specifies whether the attribute mode is preset or not.
object is the Attribute object.
Examples...
© Bricsys NV. All rights reserved. |
