Sets or returns the width of the objects such as text boundary, view, image, toolbar, or main application window.
Sets or returns the width of following objects:
Application, MText, PViewport, Raster, Shape, Text, TextStyle, Toolbar, Viewport, View
Syntax
Where:
integerVariable is a Long integer variable specifying the Width property (in drawing units).
object is the object of interest.
Application: The width of the main application window in pixels. (Integer)
Attribute, MText, Text: The width of the uppercase text. Height is measured in the drawing units. The Height property is used as a scale factor for both the height and width of the text.
Raster: (Read-Only) The width of the raster image in pixels. (Integer)
Viewport: The width of a viewport is the X axis measurement of the viewport frame.
View: The width of a view is the X axis measurement of the area within a viewport that is used to display the model.
Examples...
© Bricsys NV. All rights reserved. |
