_vlax-safearray-mode
(_vlax-safearray-mode T/NIL)
This function allows to specify, how BricsCAD
LISP engine handles an empty SAFEARRAY ...
AutoCAD treats and empty SafeArray object as
an error, i.e. with (vlax-safearray->list)
BricsCAD traditionally accepts an empty
SafeArray, like an empty list (or like NIL)
This caused some AutoLISP applications to fail
under BricsCAD;
therefore, this function can be used to
control how empty SafeArray is treated under BricsCAD;
default for BricsCAD is, to handle an empty
SafeArray the same way as AutoCAD does.
Arguments |
T/NIL |
Return |
T / NIL indicating the effective status |
Example |
(_vlax-safearray-mode T)
for an empty SafeArray, NIL is returned by
(vlax-safearray->list) |
Alias |
Remarks |
safe usage : |
