acet::normalize-filename
(BricsCAD-specific !)
(acet::normalize-filename
fileName)
This function replaces the "\\" respectively
"/" characters in the fileName(string) by the
path delimiter of the actual OS/Platform.
As Windows accepts both path delimiters, no
replacement is made under Windows;
but path delimiter effectively happens on
Linux and Mac.
Therefore, Lisp application code can safely
use this function on all platforms, the returned file name is
always suitable for the running OS/Platform.
Returns normalised file name as
string.
