bim:attributeset-set-property-visible
(bim:attributeset-set-property-description
asetName propName visible)
This function assigns the new visibility
status visible for the Property specified by its propName name, searching for
in the asetName AttributeSet.
Arguments |
asetName (string) the name of the AttributeSet to retrieve
the Property from |
Return |
T or NIL |
Example |
Remarks |
the AttributeSet name is
case-insensitive; |
