bim:attributeset-set-property
(bim:attributeset-set-property entity
asetName propName value)
This function assigns the value to the Property
propName of
AttributeSet asetName, attached to the
specified entity.
Arguments |
entity (ename or vla-object) the entity to assign the
Property |
Return |
T or NIL |
Example |
Remarks |
the AttributeSet name is
case-insensitive: |
