bim:delete-attributesets
(bim:delete-attributesets [categoryId |
categoryName])
This functions removes all AttributeSets, from
the (optionally) specified NameSpace.
Arguments
(optional)
specifies the NameSpace to remove all
AttributeSets from (each category has an associated
NameSpace)
categoryId BIM property category ID, can be omitted
(bcBimCategoryUser is used then); see Category Constants
---or---
categoryName BIM property category name as string, can be omitted
(bcBimCategoryUser is used then), see Category Constants
if omitted, the "User" NameSpace is
automatically used to search for all AttributeSets
Return
T or NIL, indicating success
or failure
Example
(bim:create-attributeset
"---testName---" "---testLabel---" T) T
(bim:has-attributeset "---testName---")
T
(bim:delete-attributesets) T
NIL
Remarks
the BIM property category
name is case sensitive;
if the NameSpace (as indirectly specified by
categoryId resp. categoryName) does not exist, it will be
automatically created, as a visible NameSpace
