bim:list-attributesets
(bim:list-attributesets [categoryId |
categoryName])
This function returns a list of all defined
AttributeSets of (optionally) specified NameSpace
categoryId | categoryName.
Arguments
(optional)
specifies the NameSpace to where to retrieve
the AttributeSets from (each category has an associated
NameSpace)
categoryId BIM property category ID, can be omitted
(bcBimCategoryUser is used then); see Category Constants
---or---
categoryName BIM property category name as string (can be an
empty string for bcBimCategoryUser), see Category Constants
if omitted, the "User" NameSpace is
automatically used
Return
a list of AttributeSet
entries, or NIL;
each entry is defined as :
(<name> <label>
<visible>)
the "visible" status (T/NIL) means whether the
AttributeSet (and its Attributes) is visible in
PropertiesPanel
Example
(bim:create-attributeset
"---testName---" "---testLabel---" T) T
(bim:list-attributesets)
(("---testName---" "---testLabel---" T))
Remarks
the BIM property category
name is case-insensitive;
if the NameSpace (as indirectly specified by
categoryId resp. categoryName) does not exist, NIL is
returned;
