bim:pset-list-properties
(bim:pset-list-properties  propertyset)
Returns a list of all defined properties for the specified PropertySet propertyset.
Arguments
propertyset  (string) the name of the PropertySet (as Name or Label, case-insensitive) to retrieve
Return
list of property definition entries, or NIL (if the ProeprtySet does not exist, or does not contain any Property);
each property definition entry is defined as :
(name  description  type)  name, description and type are all strings
the "type" string is one of the following (always lowercase) :
"integer"
specifies a Lisp INT fixed number
"double"
specifies a Lisp REAL floating point number
"string"
specifies a Lisp STR string
"point2d"
specifies a Lisp 2d point (x y)
"point3d"
specifies a Lisp 3d point (x y z)
"objectid"
specifies a Lisp ENAME
Example
(bim:pset-list-properties "Pset_ConcreteElementQuantityGeneral")
(("TotalConcreteQuantity" "The total bulk quantity of concrete used for the precast concrete element expressed as the volume of concrete in cubic meter (m3)." "double"))
Remarks
the PropertySet name/label is case-insensitive;
all PropertyNameSpaces are automatically used to find the specified PropertySet
©  Bricsys NV. All rights reserved.
