The attribute bcad_width is a BricsCAD-only attribute. If it is
specified, it is used instead of the attribute width to set a minimum width on any
tile. This allows to bypass small cosmetic problems in the BricsCAD
dcl engine. Since the BricsCAD dcl engine is implemented with
wxWidgets, some small visual differences with an MFC based dcl
engine cannot be avoided. This is however rarely needed and
normally concerns details only.
related tiles
Most tiles can have a bcad_width
attribute. It is ignored for a popup_list only.
