fixed_width
The fixed_width attribute takes a boolean value (true or false), with default value false. It has different meaning on a dialog, as opposed to other tiles. Note: if a vertical alignment of a column and sibling child tiles with a uniform space distribution is desired, it is required to enable the fixed_width attribute for the column tile. Otherwise, the column occupies more space.
related tiles
All of the child tiles or a dialog can have an fixed_width attribute..
