tin:getintersectionswithline
(tin:getintersectionswithline tinEname
point1 point2 allOrFirst
visibleOnly)
This function returns all (or first)
intersection point(s) for the tinEname TinSurface entity
with a line from point1 to point2, for all or visible
triangles.
Arguments
tinEname (ename or vla-object) the TinSurface entity to
query
point1 (3d
point list) the start point of the "line"
point2 (3d
point list) the end point of the "line"
allOrFirst (T/NIL) specifies whether all (T) intersection
points are returned, or only the first (NIL)
visibleOnly (T/NIL) specifies whether to use the triangles of
all definition points (NIL), or only the triangles of visible
points (T)
Return
(list of 3d points) the list
of 3d intersection points (one or multiple)
Example
(tin:getIntersectionsWithLine
tin '(-10 30 4) '(100 50 8) T T)
((67.44 44.08 6.816) (18.780487804878
35.2328159645233 5.04656319290466))
(tin:getIntersectionsWithLine tin '(-10 30 4)
'(100 50 8) T NIL)
'(100 50 8) NIL T)
((18.780487804878 35.2328159645233
5.04656319290466))
'(100 50 8) NIL NIL)
5.04656319290466))
Remarks
the "line" is defined as
start/end point, it is not an endless vector !
