tingr:set-midordinatedist
(tingr:set-midordinatedist grading
dist)
Assigns the 'mid-ordinate distance'
dist to be used by
the grading TinGrading entity.
Arguments
grading (ename or vla-object) the TinGrading
entity
dist (number, integer or double) the 'mid-ordinate
distance' value to be used
Return
T or NIL
Example
Remarks
see (tingr:get-midOrdinateDist);
the mid-ordinate
distance is the distance of the curve's
midpoint, to the arc center; similar to arc's bulge; used as a kind
of tolerance;
this curve rasterisation/smoothing tolerance
only applies to curve-based constraints;
default value is 0.0, which means automatic
tolerance chosen by the TinGrading implementation;
see https://civil3dplus.wordpress.com/2012/12/23/surfaces-and-the-mid-ordinate-distance/
typical values are in range : 0.01 - 0.05
(meter), 0.5 - 1.0 (inch)
