vl-annotative-set
(vl-annotative-set  enameOrVlaObject  [ scale ])
This function assigns the specified annotation scale (or the current annotation scale "CANNOSCALE") to the specified entity.
Arguments
enameOrVlaObject  ename or VlaObject
scale  (optionally) string, the annotation scale to be assigned; if omitted, the current annotation scale is assigned
Return
T if the (specified or current) annotation scale has been successfully assigned, NIL otherwise
Example
(vl-annotative-set (car (entsel)) "1:50")  T
(vl-annotative-set (vlax-ename->vla-object (car (entsel))) "1:100")  T
Remarks
if the specified entity does not support annotation scales, NIL is always returned (no error is triggered)
©  Bricsys NV. All rights reserved.
