vl-filename-mktemp
(vl-filename-mktemp [ mask [ folder [
extension ] ] ] )
This function creates a unique file name,
which can be used for temporary files.
Arguments |
mask (string, optional) pattern for the name part, can
contain a folder; if omitted or NIL, "_VL~~" is used |
Return |
(string) a unique name, suitable to create a (temporary) file |
Example |
(vl-filename-mktemp) |
Remarks |
note : only the first 5 characters from mask are taken to generate the file name ! |
