vl-load-geo
(vl-load-geo)
This function loads the Lisp engine's Civil
GeoCoordinateSystem extensions, if the license conditions are met
(Professional).
Arguments |
none |
Return |
T if Civil GeoCoordinateSystem LISP API is active, NIL otherwise (usually due to a license problem) |
Example |
Remarks |
if the Civil GeoCoordinateSystem extension is already active, this function does nothing |
