vl-load-tin
(vl-load-tin)
This function loads the Lisp engine's
TinSurface extensions, if the license conditions are met
(Professional).
Arguments |
none |
Return |
T if TinSurface LISP API is active, NIL otherwise (usually due to a license problem) |
Example |
Remarks |
if the TinSurface extension is already active, this function does nothing and returns T |
