vl-local-undo-push
(vl-local-undo-push
[entity]r)
Saves the actual status for the dwg database
(if entity is NIL or omitted) or for the specified
entity.
Arguments |
entity (ename) optionally the entity, for which the changes
will be tracked; |
Return |
always returns T |
Example |
Alias |
Remarks |
undo push and pop operations can be nested |
