vlax-add-cmd
(vlax-add-cmd globalName lspFunction [
localisedName [ cmdFlags ] ] )
This function declares lspFunction as a native
command globalName for BricsCAD.
Arguments
globalName
(string) the global command
name
lspFunction (symbol) a Lisp DEFUN function
localisedName (string, optional) the localised command name; can
be NIL
cmdFlags (integer, bit flags, optional) command
behaviour flags; if omitted, value acrx_cmd_redraw (4) is
used;
these flags can be combined (by OR)
acrx_cmd_modal
0
acrx_cmd_transparent
1
acrx_cmd_usepickset
2
acrx_cmd_redraw
4
acrx_cmd_noperspective
8
acrx_cmd_notilemode
32
acrx_cmd_nopaperspace
64
acrx_cmd_nooem
256
acrx_cmd_nohistory
8388608
acrx_cmd_no_undo_marker
16777216
acrx_cmd_nobedit
33554432
Return
string; returns
globalName or NIL
in case of an error
Example
(defun HellowWorld () (alert
"Hello World")(princ)) HELLOWORLD
(vlax-add-cmd "HelloWorld" 'HelloWorld NIL (+
acrx_cmd_transparent acrx_cmd_nopaperspace))
"HelloWorld"
command HelloWorld will only run (even as
transparent command) in ModelSpace, for PaperSpace the command is
blocked
Remarks
see (vlax-remove-cmd) function
