vlax-curve-getendparam
(vlax-curve-getendparam curveEnt)
This function returns the "end parameter" of
the curveEnt curve entity.
Arguments |
curveEnt (ename or vla-object) the COM object of any "curve" entity |
Return |
double; the end parameter of the curve or NIL |
Example |
last entity is a
LINE<0,0,0> to <10,10,10> : |
Remarks |
it is up to the curve entity
to define what it "end parameter" means - never assume a particular
meaning of "end parameter" ! |
© Bricsys NV. All rights reserved. |
