acet-geom-object-point-list
(acet-geom-object-point-list  ename  smoothness)
Returns a list of defining points for entity ename, using format (pt1 pt2 ... ptN);
all points can be 2d/3d points, depending on the entity;
smoothness is an optional double value, defining the smoothness when rasterizing the entity; if NIL, an internal default is used.
©  Bricsys NV. All rights reserved.
