Works with Classic, Pro
Creates a polar or rectangular array of entities.
command bar: array
alias: ar, -array
menu bar: Modify | 2D Array
toolbar: Modify |
: array
Select entities to array: (Select one or more entities.)
Entities in set: 1
Select entities to array: (Press Enter to end entity selection.)
Type of array: Polar/<Rectangular>: (Enter an option.)
This command creates linear, rectangular, and polar arrays.
Specifies the entities to be arrayed. Use any entity selection method; press Enter when you are done. |
Creates polar (circular) arrays. Prompts you: Type of array: Rectangular/<Polar>: (Type P.) Base/Center of polar array: (Pick a point, or type B.) ENTER to specify angle between items/<Number of items to array>: (Enter a number, or press Enter.) Angle to array (+ for ccw, - for cw) <360>: (Enter a positive or negative angle.) Rotate entities around the array? No/<Yes>: (Type N or Y.) |
Creates linear, rectangular, or square arrays. Prompts you: Type of array: Polar/<Rectangular>: (Type R.) Number of rows in the array <1>: (Enter the number of rows.) Number of columns <1>: (Enter the number of columns.) Vertical distance between rows, or spacing rectangle: (Specify the distance between rows, or pick two points.) Horizontal distance between columns: (Specify the distance between columns.) |
Rectangular arrays have rows and columns:
Polar arrays can have rotated or non-rotated entities:
3dArray - creates 3D arrays.
MInsert - inserts arrays of blocks.
