Works with Classic, Pro
Displays the Settings dialog box (short for "dynamic dialog set variables").
command bar: ddsetvar
transparent: 'About
alias: settings
: ddsetvar
Displays the Settings dialog box:
Change settings, and then click X.
Lists system variables in categories. |
Lists system variables in alphabetical order by setting name. |
Exports the settings to a .csv file (comma-separated values); displays the Export Settings dialog box. Click Save. The file can be opened in a word processor, spreadsheet, or database program. |
Jumps to the Drawing section of the dialog box. |
Jumps to the Dimensions section of the dialog box. |
Jumps to the Program Options section of the dialog box. |
Displays the Find Options dialog box:
Enter the text you wish to search for. |
Click to start the search. |
Specifies where to search for text:
Applies changes made to the Find Where options. |
Matches the pattern of upper and lowercase letters. |
Enters the name of a system variable, title, or help for Bricscad to search. The field changes color: Green - another entry exists for the search phrase; click the Find Next button. Blue - the last entry has been reached; click Find Next to start again at the beginning. Orange - text does not exist in this dialog box. |
Finds the previous entry |
Finds the next entry. |
Related Command
SetVar - change the values of system variables through the command bar.
