Works with Classic, Pro
Starts new drawings with the New Drawing Wizard.
command bar:
alias: ddnew
menu bar: File | New Wizard
: newwiz
Choose an option, and then click Next.
Press F1 to access help.
Starts new drawings with the default template file. The default DWT template file is defined by the Templates section of the Settings command (Basefile system variable). |
Starts new drawings using one of the default template files associated with these measurement systems:
Choose a measurement system, and then click Finish:
Starts new drawings with a template file:
Choose a template file, and then click Finish. STB is short for "style table," which refers to template drawings with plot styles. |
Starts new drawings with a wizard:
Choose a linear measurement unit, and then click Next.
Choose an angular measurement unit, and then click Next.
Choose whether the drawing uses color-dependent plot styles or named plot styles:
Click Next.
Choose the default working color and linetype:
Toggle the grid, snap, UCS icon, and marker blips:
Click Finish. |
Units - sets units through the Settings dialog box.
-Units - sets units through the command bar.
New - starts new drawing in Imperial or metric units.
QNew - opens new drawings.
