Works with Classic, Pro
Pastes entities from the Clipboard through a dialog box (short for "paste special").
command bar: pastespec
alias: pa
menu bar: Edit | Paste Special
: pastespec
Choose a format, and then click OK.
Pastes the entities in the drawing. If the entities are in Bricscad format, you are prompted: Select insertion point - specify the insertion point of the entities. If the entities are in other formats, the entities are pasted in the upper left corner of the viewport. |
Pastes the entities in the drawing, and creates a link to the originating application. |
Chooses the format in which to paste the entities. This list varies, depending on the content of the Clipboard. |
Displays the pasted entities by their source icon. |
CopyBase- copies selected entities to the Clipboard with a base point.
CopyClip - copies selected entities to the Clipboard.
CopyHist - copies all text from the Text window to the Clipboard.
CutClip - cuts (moves) selected entities to the Clipboard.
PasteBlock - pasted entities from the Clipboard as a block at an insertion point.
PasteClip - pastes entities from the Clipboard into the current drawing.
