ReInit
Works with Classic, Pro
Reloads the PGP alias file (short for "reinitialize").
command bar:  reinit
alias:  ri
: reinit
Click OK or Cancel.
This command is used to load the PGP file after it has been edited externally.
The PGP file defines command aliases. See the "Customizing Bricscad" ebook for details on aliases.
OK
Reloads the PGP file into Bricscad.
Cancel
Does not reload the file.
Related Command
Customize - creates and edits aliases.
