Works with Classic, Pro
Renames named entities through the Drawing Explorer.
command bar: rename
aliases: ren, ddrename
: rename
Displays the Drawing Explorer:
To rename an item, click twice on its name (don't double-click!), and then enter the new name.
Alternatively, right-click the name, and then choose Rename from the shortcut menu.
You can change the names of most layers, layer states, most linetypes, UCSs, views, blocks, most text styles, and most dimension styles.
You cannot change the names of attached images and external references.
You cannot change the following names:
Layers - 0
Linetypes - ByBlock, ByLayer, Continuous
Text styles - Standard
Dimension styles - Standard
To rename at the command line, use the -Rename command.
No options.
Related Command
-Rename - renames commands through the command bar.
