ShadeMode
Works with Classic, Pro
Sets the shading style for 3D drawings.
command bar:  shademode
alias:  vscurrent
: shademode
Current mode: 2D wireframe
Enter option [2D wireframe/3D wireframe/Hidden/Flat/Gouraud/Flat+edges/gOuraud+edges] <2D wireframe>: (Enter an option.)
The shade mode is applied to the drawing immediately.
You can draw and edit in any of these shade modes.
For more realistic renderings, use the Render command (Pro version only).
2D wireframe
Displays drawings in 2D wireframe mode.
This is the normal mode for viewing drawings in Bricscad.
3D wireframe
Displays drawings in 3D wireframe mode.
This mode may display certain items differently from 2D wireframe mode.
Hidden
Displays drawings in hidden mode.
Hidden lines are removed.
Flat
Displays drawings in flat rendered mode.
Facets are not smoothed.
This is the mode used by the Shade command.
Gouraud
Displays drawings in Gouraud rendered mode.
Facets are smoothed.
Flat+edges
Displays drawings in flat rendered mode, with edges outlined in the background color.
gOuraud+edges
Displays drawings in Gouraud rendered mode, with edges outlined in the background color.
