Works with Classic, Pro
Creates freehand sketches.
command bar: sketch
alias: freehand
menu bar: Insert | Sketch
toolbar: Draw 2D | ![]()
: sketch
Freehand: Length of segments <0.1000>: (Enter a number, or press Enter to accept the default.)
Press ENTER to end/Pen down/(Begin...) (Move mouse to create sketch. Press Enter to end.)
During sketching, the lines are green:
Press ENTER to end/Pen up/Quit/Delete on/Connect/Straight to cursor/Write to drawing/(Sketching...): (Enter an option, or press Enter to exit command.)
Do not press Enter after entering an option!
Writing freehand sketch to drawing...
Sketches are made from polylines.
Specifies the length of segments. Enter a number. Too small a segment length results in large drawings. |
Draws as the cursor is moved. |
Allows you to move the pen without drawing.
Exits the command without saving the sketch. |
Erases the sketch interactively.
Connects cursor to end of segment; prompts you: Move cursor to end of last freehand segment - move the cursor to the end of a sketch. This option is meant for use after a pen up, or when restarting the Sketch command. |
Draws a straight segment to the current cursor location.
This option works only when the pen is up. |
Saves the sketch; reports: Writing freehand sketch to drawing. |
PLine - draws polyline segments and arcs.
RevCloud - draws revision clouds.
Settings - sets parameters for sketches.
