Works with Classic, Pro
Visually changes the size of the drawing within the current viewport.
command bar: zoom
transparent: 'zoom
alias: z
menu bar: View | Zoom
toolbar: View | ![]()
: zoom
Zoom: In/Out/All/Center/Extents/Left/Previous/Right/Window/<Scale (nX/nXP)>: (Enter an option, or pick two points for a windowed zoom, or enter a zoom factor.)
To zoom in and out at any time, roll the mouse's wheel back and forth.
Specifies the absolute zoom scale factor:
Specifies the zoom factor relative to the current zoom. For example, 2x makes the current view twice as large. |
Specifies the zoom factor in paper space relative to model space. For example, 2xp makes the model space view twice as large as the surrounding paper space. |
Zooms in by 50% (0.5) |
Zooms out by 50% (2.0). |
Displays the entire drawing; zooms to the larger of:
Zooms in or out about a specified center point; prompts you: Center of view - pick a point or enter x,y coordinates. Enter zoom factor (nX/nXP), or view height - enter a zoom factor or view height. The view height defines the zoom; it is the height of the current viewport.
Displays the drawing to the extents of entities; limits and frozen entities are ignored.
Zooms in or out with the lower left corner specified by a point; prompts you: Lower left corner - pick a point or enter x,y coordinates. Enter zoom factor (nX/nXP), or view height - enter a zoom factor or view height. The view height defines the zoom; it is the height of the current viewport.
Displays the previous view, whether set by the Zoom, Pan, or View commands. |
Zooms in or out with the upper right corner specified by a point; prompts you: Upper right corner - pick a point or enter x,y coordinates. Enter zoom factor (nX/nXP), or view height - enter a zoom factor or view height. The view height defines the zoom; it is the height of the current viewport.
Zooms in to a rectangular area; prompts you: First corner - pick a point or enter x,y coordinates. Opposite corner - pick another point or enter x,y coordinates.
RtZoom - performs real-time zooming of the drawing.
Pan and -Pan - move the drawing within the current viewport.
RtPan - performs real-time panning of the drawing.
View and -View - set up named views of drawings.
DdVPoint - changes the 3D viewpoint of the drawing through a dialog box.
VPoint - changes the 3D viewpoint of the drawing through the command bar.
RtRot - rotates the 3D viewpoint in realtime.
RtRotX - rotates the 3D viewpoint about the x axis in realtime.
RtRotY - rotates the 3D viewpoint about the y axis in realtime.
RtRotZ - rotates the 3D viewpoint about the z axis in realtime.
