Bricscad Pro provides a C/C++ API, called the "BRX API". BRX stands for "Bricscad Runtime eXtension".
Code compatibility
BRX is 100% code compatible with the standard C++ interface of AutoCAD, ObjectARX. As an application developer, you only need to maintain one set of source code for your modules, to serve multiple CAD platforms:
Besides different header include paths and lib paths, the settings can be identical. Note that binary compatibility is not available: a module compiled with ObjectARX can not load in Bricscad, and visa versa a module compiled with the BRX SDK can not load in AutoCAD.
Features
A glimpse of the various items supported in BRX:
Please note that this list is not limitative.
Version
BRX is code compatible with ObjectARX version 2007 (or higher), as a consequence all the interfaces support unicode.
Compiling BRX applications
Your application needs to be compiled with Visual Studio 2005 (Service Pack 1 recommended), or any higher version that is compatible with version 8.0 of the Microsoft CRT and MFC libraries.
Sample
Amongst the sample applications installed with Bricscad, you can find a BRX sample project that shows some features of the BRX API (custom entity, dockable dialog, ...). The sample contains different build configurations, targeting Bricscad and AutoCAD. The code can be compiled with the BRX SDK and ObjectARX, and the identical behavior can be checked on both CAD platforms.
Quality Assurance
Alongside with the development of the BRX SDK, Bricsys has developed an extensive suite of automated tests, to back up all supported BRX functions. Every function is checked for normal operation and error return values. By this way we maximize:
BRX SDK
The BRX SDK consists of:
The BRX SDK is not installed with Bricscad itself, but is distributed through a separate download source. You can get free access to the BRX SDK, simply by registering yourself as an application developer on the Bricsys website (www.bricsys.com). During registration, mark the check box for "ARX/BRX/DRX", and you will receive the necessary information to get started.
F.A.Q.
On the Bricsys website (www.bricsys.com), support section, check our knowledge base for frequently asked questions and answers. Search for the keyword "BRX" to find the related topics.
Final notes
