Specify the width of a tile.
This attribute specifies the minimum width of a tile. The width is automatically changed by the program unless established by the fixed_width attribute.
In general, use the width attribute with the image and image_button tiles. For other tiles, do not use this attribute unless you need to improve the appearance of the dialog box.
number: any real number or integer in units of character width. The "character width unit" is the lessor of either:
Example
NOTE The aspect_ratio attribute is used with either the height or width attribute. Do not use the aspect_ratio attribute when using both height and width.
Valid Tiles
all tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
