Hatching fills a specified area with lines, crosshatching, or other hatch patterns.
The first step in hatching an area is to create the Hatch object. Once this is done, you specify the hatch boundaries.
To create a hatch object, use the AddHatch method.
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
