Activate method example
Sub Example_ActivateMethod()
Dim dwg1 As AcadDocument: Set dwg1 = ThisDrawing.Application.Documents.Add("")
Dim dwg2 As AcadDocument: Set dwg2 = ThisDrawing.Application.Documents.Add("")
Dim theDwg As AcadDocument
For Each theDwg In ThisDrawing.Application.Documents
theDwg.Activate
MsgBox "Drawing " & theDwg.Name & " is active."
Next theDwg
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
