AddHatch method example
Sub addHatchExample()
addHatchPreDefined
addHatchUserDefined
End Sub
Private Sub addHatchUserDefined()
Dim hatchObj As AcadHatch
Dim patternName As String
Dim patternType As AcPatternType
Dim bAssociativity As Boolean
patternName = "_USER"
patternType = acHatchPatternTypeUserDefined
bAssociativity = True
Set hatchObj = ThisDrawing.ModelSpace.addHatch(patternType, patternName, bAssociativity)
Dim outerLoop(0 To 0) As AcadEntity
Dim center(0 To 2) As Double: center(0) = 10: center(1) = 5: center(2) = 0
Dim radius As Double: radius = 3
Set outerLoop(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
hatchObj.AppendOuterLoop (outerLoop)
hatchObj.Evaluate
ThisDrawing.Regen True
End Sub
Private Sub addHatchPreDefined()
patternName = "ANSI31"
patternType = acHatchPatternTypePreDefined
Dim center(0 To 2) As Double: center(0) = 5: center(1) = 5: center(2) = 0
hatchObj.Evaluate
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
