Add3dFace method example
Sub Add3dFaceExample()
Dim Pt1(0 To 2) As Double: Pt1(0) = 0: Pt1(1) = 0: Pt1(2) = 0
Dim Pt2(0 To 2) As Double: Pt2(0) = 3: Pt2(1) = 0: Pt2(2) = 2
Dim Pt3(0 To 2) As Double: Pt3(0) = 6: Pt3(1) = 5: Pt3(2) = 0
Dim Pt4(0 To 2) As Double: Pt4(0) = 4: Pt4(1) = 4: Pt4(2) = 2
Dim faceObj As Acad3DFace
Set faceObj = ThisDrawing.ModelSpace.Add3DFace(Pt1, Pt2, Pt3, Pt4)
faceObj.Update
ThisDrawing.Application.ZoomExtents
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
