Sub AddMtextExample()
' This example creates Mtext and adds it to the drawing using the
Sub AddMtextExample() ' This example creates Mtext and adds it to the drawing using the ' AddMtext method. Dim sBuf As String Dim oMtext As AcadMText Dim insPt(0 To 2) As Double insPt(0) = 0: insPt(1) = 9 Dim dWidth As Double dWidth = 50 sBuf = "Line one of test string for the AddMtext method" sBuf = sBuf & vbCrLf & "Line two of test string for the AddMtext method" sBuf = sBuf & vbCrLf & "Line three of test string for the AddMtext method" ' Add the mtext Object Set oMtext = ThisDrawing.ModelSpace.AddMText(insPt, dWidth, sBuf) oMtext.width = dWidth oMtext.Height = 1 oMtext.Update ThisDrawing.Application.ZoomExtents End Sub
