AngleToString method
Converts an angle to a string.
Syntax
     object.AngleToString(Angle, [Unit], Precision)
Where:
     object is the Utility object;
     Angle is a double-precision variable (or value) representing an angle;
     Unit is one of the following AngleUnits from which the angle will be converted:
     acDegreeMinuteSeconds = 1
     acDegrees = 0
     acGrads = 2
     acRadians = 3
     acSurveyorUnits = 4
     Precision is a Long integer variable (or value) representing the number of decimal places for the angle.
