Sub DetachXRef_Example()
' This example adds and detaches an external reference using the MAP.DWG file.
' You may need to change the path and filename for your system.
Dim insPt(0 To 2) As Double
Dim insertedXRef As AcadExternalReference
Dim sFullPathName As String: sFullPathName = "c:\map.dwg"
Dim sXrefName As String: sXrefName = "The Map"
insPt(0) = 0: insPt(1) = 0: insPt(2) = 0
' Add the external reference to the drawing
Set insertedXRef = ThisDrawing.ModelSpace.AttachExternalReference( _
sFullPathName, sXrefName, insPt, 1, 1, 1, 0, False)
MsgBox "The external reference '" & sFullPathName & "' is attached as '" & sXrefName & "'."
' Detach the external reference definition
Dim name As String
name = insertedXRef.name
ThisDrawing.Blocks.Item(name).Detach
MsgBox "The external reference '" & sXrefName & "' is detached."
End Sub
