Sub Example_DisplayMethod()
' This example creates a paper space viewport and makes it active.
Dim newPViewport As AcadPViewport
Dim centerPoint(0 To 2) As Double
Dim height As Double
Dim width As Double
height = 30#
width = 40#
centerPoint(0) = 30#: centerPoint(1) = 30#: centerPoint(2) = 0#
' Create a paper space Viewport object
ThisDrawing.ActiveSpace = acPaperSpace
Set newPViewport = ThisDrawing.PaperSpace.AddPViewport(centerPoint, width, height)
ZoomAll
newPViewport.Display True
' Before making a pViewport active,
' the mspace property needs to be True
ThisDrawing.MSpace = True
ThisDrawing.ActivePViewport = newPViewport
ThisDrawing.Regen (acAllViewports)
End Sub
