Sub GetUCSMatrix_Example()
' This example creates a new UCS and finds the UCS matrix for it.
' It then creates a circle using WCS coordinates and
' transforms the circle for the UCS.
' Define a new UCS and turn on the UCS icon at the origin.
Dim ucsObj As AcadUCS
Dim origin(0 To 2) As Double
Dim xAxisPoint(0 To 2) As Double
Dim yAxisPoint(0 To 2) As Double
origin(0) = 2: origin(1) = 2: origin(2) = 0
xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) = 0
yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) = 0
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
ThisDrawing.ActiveUCS = ucsObj
ThisDrawing.ActiveViewport.UCSIconOn = True
ThisDrawing.ActiveViewport.UCSIconAtOrigin = True
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
' Create a circle using WCS coordinates
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 1: center(1) = 1: center(2) = 0
radius = 0.5
Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
ZoomAll
' Get the UCS transformation matrix
Dim TransMatrix As Variant
TransMatrix = ucsObj.GetUCSMatrix()
' Transform the circle to the UCS coordinates
MsgBox "Transform the circle.", , "GetUCSMatrix Example"
circleObj.TransformBy (TransMatrix)
circleObj.Update
MsgBox "The circle is transformed.", , "GetUCSMatrix Example"
End Sub
