Open method example
Sub Open_Example()
The following example opens "C:\package.dwg" file.
You may need to change the drawing path and name to reflect a
valid
Bricscad drawing on your system.
ThisDrawing.Application.Documents.Open
("C:\package.dwg")
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
