Sub Rotate3D_Example()
' This example creates a cone in model space.
' It then rotates the cone about an axis.
Dim coneObj As Acad3DSolid
Dim conePt(0 To 2) As Double
Dim rotPt1(0 To 2) As Double
Dim rotPt2(0 To 2) As Double
conePt(0) = 2: conePt(1) = 2: conePt(2) = 0
rotPt1(0) = 1: rotPt1(1) = 2: rotPt1(2) = 0
rotPt2(0) = 3: rotPt2(1) = 4: rotPt2(2) = 0
Set coneObj = ThisDrawing.ModelSpace.AddCone(conePt, 3, 4)
coneObj.Update
' Rotate the cone
coneObj.Rotate3D rotPt1, rotPt2, 10
ThisDrawing.Application.ZoomAll
End Sub
