ZoomScaled method example
Private Sub
ZoomScaledExample()
' This example creates a line
and adds it to the drawing using the AddLine
' method. It then uses the
ZoomScaled method to zoom in at a desired scale.
Dim myDoc As
IntelliCAD.Document
Dim myLine As
IntelliCAD.Line
Dim myStartPt As
IntelliCAD.Point
Dim myEndPt As
IntelliCAD.Point
Set myDoc =
Application.ActiveDocument
Set myLine =
myDoc.ModelSpace.AddLine(Library.CreatePoint(4, 4),
Library.CreatePoint(7, 1))
myLine.Update
Me.hide
ThisDocument.ActiveViewport.ZoomScaled
0.5, vicZoomScaledRelative
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
