Class AcadDatabasePreferences
Member of BricscadDb
The DocumentPreferences object contains certain settings for the active document (drawing). The settings of a document that are saved in a drawing (not the registry).The DocumentPreferences object has no applicable methods, but can be accessed with the following properties:
Properties |
Application |
ContourLinesPerSurface |
DisplaySilhouette |
MaxActiveViewports |
Parent |
RenderSmoothness |
SegmentPerPolyline |
SolidFill |
TextFrameDisplay |
XRefLayerVisibility |
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
