Class AcadLineType
Member of BricscadDb
The Linetype object defines the appearance of a line. A line can be solid (continuous) or a pattern of dashes, dots, and blank spaces. To access the Linetype object, use the following methods and properties:
| Methods | Properties |
| Delete | Application |
| GetXData | Description |
| GetExtensionDictionary | Document |
| SetXData | Handle |
| HasExtensionDictionary | |
| Name | |
| ObjectID | |
| ObjectName | |
| OwnerID |
